On the MX models is the total VPN throughput the combine throughput of both wan ports or is the throughput for each WAN port? We are moving away from MPLS and I am trying to figure out speeds for each of my wan ports.
I've never seen any official statement regarding that. But if I were to guess, I'd say it's aggregated VPN throughput over all tunnels, regardless of whether that's WAN1 or WAN2, or whether it's AutoVPN or 3d party VPN.
From what I understand, it's aggregated throughput and limited more by internal hardware than uplink speed. You also have to take that max tunnel number with a grain of salt.
Can it form the max tunnel number? Sure! Are those tunnels going to have great performance? Probably not.
I would say it is a hardware limit since the traffic is encrypted to some extent and that takes overhead. All the MX devices have lower VPN throughput than total throughput. Is there a specific device or use case you are trying to analyze?
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6ed46af050ade4","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6ed46af050ade4_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6ed46af050ade4_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6ed46af050ade4_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_6ed46ae8615901","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
