VPN Client with Site-to-Site VPN
LucL
I got some problem to configure my Client VNP to access to the second site on Site-to-Site VPN.
The organisation is :
Site 1 - Main site - configured in Hub (in Site-to-Site setting)
IP : 192.168.111.0/24 and 192.168.110.0/24
Site 2 - Second site - configured in Spoke (in Site-to-Site setting)
IP : 192.168.113.0/24
The Client VPN is configured on the Site 1.
I have access to the Site 1 with my VPN Client.
But I don't have access to the Site 2.
I don't really want to configure a new VPN Client on Site 2, I would like to prefer if the VPN Client from Site 1 have access to Site 2.
On the Site-to-Site setting in the Site 1, I have approved the Client VPN in VPN mode.
On the Site-to-Site setting in the Site 2, I have this :
Does anyone have a suggest ?
Thank you
Luc
8 REPLIES 8
Are you using split or full tunnel client vpn?
Do you have any sts-vpn firewall rules configured?
LucL
Hi @ww ,
Where do you see if it's split of full tunnel client ?
I think full tunnel, but I don't see this option in the VPN Client / IPsec Settings webpage.
For the Site-to-Site VPN, The Inbound firewall logging is Enable, but there are no rules in the Site-to-site outbound firewall.
That should work.
On site 2, if you look in the route table for the client VPN subnet does it show a route via site 1?
Hi @PhilipDAth ,
No, I don't see this route with the client VPN.
Here is the route table for the site 2:
172.16.2.0/24 is in the route table (second to bottom).
Have you got a second client you can test with?  I'm most suspicious of the computer running the client VPN having the issue.
Oh yes I didn't see it
Ok I will try this week-end at home and I will come back to you next week 🙂
Thank you for the response !
I have tried with a other computer, I got the same issue.
I can't have access to the second site with the VPN.
For your information, firewall are in MX.16.16.4
Luc
LucL
Does anyone know how to have access to the route log, if I can see something ?
Luc
