VPN Client Timeout
robdewhurst796
VPN Client Timeout
Can anyone tell me how to change the lease time to 1 week or to drop when not being used please?
I have a MX84 which is kicking my clients after 12 hours while they are running queries!
5 Replies 5
I'm not sure it is a lease that is expiring, on our (non-Meraki) client VPN it re-keys every 8 hours, resulting in the user hacing to enter a new 2FA code.  So I think you'd need to increase that interval.
robdewhurst796
How would I increase the interval on windows, mac and linux vpn clients please?
There is no VPN client idle time out "standard".  You can't configure one via the Dashboard.
I think you can use RADIUS to pass back an idle timeout.  I think I have done this once.  If you are using RADIUS authentication, check your RADIUS server if you have this configured.
That that some consumer CPE devices might time out UDP NAT translations after a fixed period of time.  So the issue could be because of the home routers in use.
You could consider changing to the AnyConnect VPN client (which has fewer of these issues).  Check you are using a compatible MX.  Note that AnyConnect licences are something extra you have to buy, but they are not expensive.
https://documentation.meraki.com/MX/AnyConnect_on_the_MX_Appliance
robdewhurst796
I am not using radius currently as we use google suite for our permissions and authentication. I have Linux, mac and windows in my environment. They all use their os standard vpn clients. Currently AnyConnect is not viable.
If there is anyway of configing the vpn clients or the mx84, it would be most appreciated
In that case, there is nothing on the VPN client or the MX that has an idle timeout setting.
The most likely issue will be a CPE device in between the two.  You could try updating the firmware on those devices.
