VPN Client Issue
LaithCpE
VPN Client Issue
I have an issue with a client of mine, I configured for him VPN client in his windows 10 machine, and we tested it in Saudi Arabia and it was working fine, then this client travelled to Egypt to work from there, but the VPN connection was denied due to the Error 789,
We checked with Meraki Support and we found out that the request of the port 4500 is being blocked from the internet ISP for my client home internet, we tested multiple ISPs there and it appears it is the same issue, the port 4500 is blocked.
How can we solve this issue? anybody has a workaround to mitigate this?
Thanks Guys,
DarrenOC
Hi @LaithCpE , unfortunately you’re not going to be able to change the ports that the client VPN is using.
Are you able to bring the user in via another route? RDP from remote IP to an internal machine maybe?
KarstenI
I would deploy a dedicated VPN-gateway with a TLS-based remote-access-VPN. Works better in many of these restricted scenarios. A Cisco Firepower Appliance with AnyConnect could be used.
BrandonS
Maybe a bit of a stretch and a chore, but I understand Meraki has AnyConnect client VPN under beta.  You could ask support about enabling it and see if it works from that location. I have no idea if it uses different ports and protocols, but it may.
