VMX100 with azure firewall routing
Shockey074
I just wanted to see if anyone has been able to put a vmx behind an azure firewall? Right now we have vmx100 in azure and it works great however we want to add a firewall but i don't fully understand how we can achieve this with the routing cause right now all the subnet's route to the vmx but in the azure doc it suggest's we route them to firewall instead.
thanks
1 REPLY 1
Inderdeep
@Shockey074 : Check this thread
https://community.meraki.com/t5/Security-SD-WAN/vMX-in-Azure-should-it-could-it-be-behind-an-Azure-F...
Regards/Inder
www.thenetworkdna.com
