VMX in Azure
Adeldardari
VMX in Azure
Hi All,
I got a design question. Can Meraki VMX be my primary Azure Gateway/Firewall ?
Further details:
Planning to have some applications services in Azure cloud (IAAS/PAAS) , those applications can be access via private link ( site to site IPSEC) or via Public IP Address. I was wondering if VMX can behave as "windows defender" and be the gateway where Azure sits behind it ( i know technically it cannot be done, but just wondering if there is a work around solution to achieve my goal )
If can't , i am wondering where do i place VMX in the design , do i give it private or public IP ( or both) to still have access to internet and also to access local resources that would be behind Azure firewall
Appreciate your feedback
1 Reply 1
It is only used for SD-WAN connectivity (and potentially client VPN).
This is the deployment guide.  I would recommend changing to "passthrough" mode before deployment.
https://documentation.meraki.com/MX/MX_Installation_Guides/vMX_Setup_Guide_for_Microsoft_Azure
