VLAN/DHCP Issue
lucafabbri365
VLAN/DHCP Issue
I have clients connected to a SSID that are not receiving IP address. This is the error appearing on SA:
DHCP problemextra: no_offers_received, vap: 0, vlan: 10
MX64 has two VLANs:
Guest network: VLAN 3 - 172.30.2.0/24 - IP 172.30.2.254
Office network: VLAN 10 - 172.18.0.0/16 - IP 172.18.0.130
DHCP is enabled on SA for both VLANs.
All SA ports are in Trunk - Native VLAN 10 - Allowed VLANs: all
MR33 have two SSID:
Guest - VLAN 3
Office - VLAN 10
- Wired clients (VLAN 10) get their IP address
- Wireless clients (VLAN 3) get their IP address
- Wireless clients (VLAN 10) cannot get their IP address and I found the error above in Event Log
Please, can you give me some helpful information to troubleshoot ?
Thank you,
Luca
12 REPLIES 12
NolanHerring
Re: VLAN/DHCP Issue
Is your MX the one supplying DHCP (acting as the server) or is that another server somewhere else?
Also, is your scope size accurate? I see you showing it as a /16
If your MX is doing DHCP I believe from recent discussions that doing a /16 is too large for it to process locally.
If it is not doing DHCP, you need to make sure you have a relay setup for the actual DHCP server (possibly).
Nolan Herring | nolanwifi.com
TwitterLinkedIn
lucafabbri365
Re: VLAN/DHCP Issue
Hello Nolan,
here the answer to your points:
1. MX is the one supplying DHCP
2. The scope is /16: the network defined in SA is /16. Even if larger network was defined in SA, I know Meraki's DHCP will serve /19 only; so if I'm not wrong the DHCP range should be 172.18.0.0/19 (172.18.0.1 - 172.18.31.254); they are, however 8190 hosts (here I have 150 hosts at maximum).
3. The problem occurs with one SSID (that belongs to /16); no problem with wired clients on same VLAN 10
4. I don't have a relay because DHCP is provided by MX
NolanHerring
Re: VLAN/DHCP Issue
Ok, well I honestly don't know how the /16 vs /19 will work (if it actually impacts anything), so lets assume its not that.
Can you validate the Access Control setting for the 'office' SSID is set correctly.
Also, can you show the switch port configuration for where the AP connects to.
Its possible the switch port is not allowing VLAN 10 for example etc.
TwitterLinkedIn
lucafabbri365
Re: VLAN/DHCP Issue
Hello Nolan,
I validated Access Control setting for office SSID; I made this test:
if I specify the VLAN 10 => I have the problem: clients connected to this SSID cannot get their IP address
if I don't specify any VLAN tagging => clients get their IP address correctly (172.18.0.0/16 VLAN 10)
I have MX; one AP is directly connected to the MX; the other APs are connected to two network switches (not Meraki).
Now I'd like to make this test: connect a client to the AP (SSID "office" configured with VLAN 10 tag)  directly connected to Meraki SA => it should get the IP address because there are no devices in the middle.
So maybe there is some issue on these two switches ?
lucafabbri365
Re: VLAN/DHCP Issue
Hello Nolan,
just an update to my latest answer.
Even if I have an AP directly connected to SA (to exclude any switch in the middle), if I set the VLAN 10 for SSID "office", clients don't get the IP address, but if I don't set any VLAN for SSID, they get the IP address.
So, please, can you confirm this: if the Native VLAN 10 is set on SA I don't have to set any VLAN on SSID "office" ?
Thank you very much for your help,
much appreciated.
Regards,
Luca
rbnielsen
Re: VLAN/DHCP Issue
If VLAN10 is native try keeping the VLAN ID field empty on the AccessControl Page for the SSID, but keep VLAN tagging enabled.
lucafabbri365
Re: VLAN/DHCP Issue
Hello rbnielsen,
what's the difference between leaving VLAN tagging enabled (but empty) and VLAN tagging disabled ?
Thank you,
Luca
rbnielsen
Re: VLAN/DHCP Issue
It is whether or not you are utilizing IEEE802.1Q  to tag frames.
Leaving the VLAN ID field empty, you are not tagging the frames, but they are still using 802.1q trunking.
https://documentation.meraki.com/zGeneral_Administration/Tools_and_Troubleshooting/Fundamentals_of_8...
lucafabbri365
Re: VLAN/DHCP Issue
Hello rbnielsen,
I cannot enable VLAN tagging and leave VLAN ID empty: I get an error while saving:
There were errors in saving this configuration:
  • One or more errors occurred. No changes have been saved.
  • Could not find a default vlan id for all other APs.
So I assume the VLAN tagging shouldn't be enable if I don't have to use it.
rbnielsen
Re: VLAN/DHCP Issue
Huh... That's odd... I'm getting the same error... I'm certain I've done this earlier...
NolanHerring
Re: VLAN/DHCP Issue
If you remove the native VLAN 10 from the switch port, then you should be able to assign VLAN 10 onto the SSID. If you leave native VLAN 10, then you don't need to specifiy it on the SSID.
I personally am not a fan of this approach.
I use the native VLAN on trunk ports for the access points so that it places them on the VLAN (management), and then the actual VLANs I use for end-users (data vlans etc) are different.
TwitterLinkedIn
lucafabbri365
Re: VLAN/DHCP Issue
Hello Nolan,
I completely agree with you.
I should define a VLAN (1 for example) for management only; set it as native and use any VLANs for all the rest.
Regards,
Luca
