Using vMX100 in Azure to connect to Azure VMware Solution
Mojoooo0
Hello there,
We seem to be having issues issues communicating to our azure vmware solution environment from our on prem meraki sites via meraki vmx100 in azure. the vmx100 can communicate to both sides (the vmware and on prem) with no issue but the vmware and on prem cannot communicate using the vmx100. We are using the route table as per meraki instructions.
When we connect to the vmware environment using a azure virtual wan setup and have it connect to meraki via non meraki site to site tunnel, there is no issues.
What are we missing here?
1 REPLY 1
janakcs
You can check out for the solution over here: https://attariclasses.in/microsoft-azure-certification-training-online/ I have found some success in the problem that I was facing.
