User-based Policy not per device!
ahmadtat
We're having this request that MX100 (or any MX) needs to authenticate users based on their credentials (not their Mac-address) or devices. in a case like below:
same PC is used by 2 users (at different shifts) .. the shifts are not really time specific (so Policy scheduling will not resolve this).
We did Active Directory integration and we can use MX with a splash page to authenticate the users by their credentials.. but the issue in this scenario is that we can only control the splash page frequency (by hours , days, weeks).. but that will not resolve the time slot differences in our case.
If there is a way to authenticate users (and then apply certain polices on) without a splash page, that would be great.. if not, how can we resolve this issue ?
6 Replies 6
I'm sorry to say but I do not believe this is possible.  The entire Meraki model is based around device enforcement.  Even when you authenticate it just associates this with the device and then enforces that device.
MilesMeraki
Hello @ahmadtat; Welcome to the community! You're post is a little confusing. However, my recommendation is to look into 802.1x intergration with AD - This assumes you are using a full stack Meraki deployment. - This assume that the respective users would log-out from the machine before finishing their shifts.
I like the 802.1x idea!  It should not be that much of a discipline for users to log in and out of their machines.  You can set group policy to lock their machines if idle for (say) 5 minutes.  Then if someone forgets to logout the next user will be forced to log back in again as they wont have the credentials of the prior user.
Thanks for your input.. will the 802.1x work if we only have the MX100?
Meaning: we don't have Meraki switches or APs yet.. we have a mix of Cisco catalyst and Linksys switches and Cisco APs.
Appreciate your feedback.
No, it wont work in that case.
bblank05
We are having the same issues. Been working with support for weeks now and still nos resolve. We have an MX100 firewall and it randomly will not apply the group policies that we set in Meraki that integrates with active directory. I can sign into 3 machines with my username and 2 out of the 3 machines will block access to certain sites. Basically it is applying the default policy to my account on two out of three machines. Big problem when you are the Admin and cant get to resources you need. This is also a problem due to the fact that a default user that needs restricted access to certain sites now have full access at random. When looking at the MX100 you will see the IP address doesn't match up with the logged in user. I see other users getting my policy that shouldn't.
This is a HUGE security flaw that needs to be addressed and right now with it coming up top three weeks of an issue. The only TEMPORARY fix is to white-list the IP address but if it doesn't have a static IP then someone else will get a white-listed IP that shouldn't when they get a DHCP release.
Not sure if this is just me but i feel like Meraki is dragging their feet on this.
