Upstream ISP firewall issue/blockage
HBWaninara
Is there a workaround to the issue of upstream ISP firewall preventing the creation of tunnel between two MXs? Without having to contact ISP to adjust configuration for your case? This is dedpite having passed the vpn registery connection process.
6 Replies 6
Stealth_Network
Can you just use traditional IPSEC VPN between them?
HBWaninara
You mean configure both MXs as non-meraki peers, instead of using auto vpn?
Stealth_Network
Yes, for testing
HBWaninara
Thanks. We'll give it a try and see.
If the upstream ISP is blocking your traffic then it won't be something Meraki can fix or something you can manually configure around.  If they are blocking your traffic they are blocking your traffic.
In the first instance, I would talk to them and see if they can offer you an alternative Internet service where they don't block your traffic.
Otherwise start looking at new ISPs.
HBWaninara
Thank You. I think this is the only more ethical approach to the issue.
