Unable to restrict AnyConnect VPN clients from accessing LAN or VLAN resources
KenLux
I'm trying to do something that this link says I should be able to do - restrict VPN clients from accessing certain resources on a local VLAN.
https://documentation.meraki.com/MX/Client_VPN/Restricting_Client_VPN_access_using_Layer_3_firewall_...
This documentation appears to be incorrect. At least for AnyConnect VPN clients. I have applied L3 firewall rules to deny all access from my VPN subnet to a VLAN subnet and to deny all access from the VLAN subnet to my VPN subnet. Yet I can access a web server on the VLAN subnet from a client on the VPN. I also tried blocking access from a single VPN IP address to a single server (and Exchange server). I can send and receive email through the "blocked" exchange server.
Other people have posted that these rules should be applied on the site-to-site VPN page, and I have tired that, but can still VPN clients have full access to everything on the LAN no matter what L3 firewall rules are in place.
Using an MX84 (18.107.2) and AnyConnect VPN clients.
Is this a known security flaw? It seems like a giant hole.
Has anyone been able to block access to any LAN resources from an AnyConnect VPN client?
KenLux
So I was able to get it to work using a L3 rule in a Group Policy.
I really wish the documentation didn't say to use settings that do absolutely nothing.
Now if I could get the MX to sop relaying pings.
KenLux
Ryan_Miles
Just tested it the regular L3 FW rule works here. Source object has both my L2TP and AnyConnect VPN subnets. You can see the hit counter.
My config
And pings from my AnyConnect VPN connected client (first blocking then allowing when I changed the FW rule to allow).
harmankardon
Can you clarify, did you try implementing the L3 firewall rules on just the site-to-site VPN page, or did you also try on the Firewall page? What you are trying to accomplish should be done on the Firewall page under Layer 3 Outbound rules (assuming the VLANs you are trying to restrict access to are local to the MX that is being used at the AnyConnect server).
And perhaps you can share with us the rules you are applying.
