URL Filtering only for a specific SSID / VLAN
Captain
Dear Community,
We have a network with many SSID's each SSID has its own tag VLAN.
We are looking into a way to filter traffic on one specific vlan / ssid to achieve the following:
   * Block access to any URL except one or many specific URLs
How can it be done?
Thanks in advance,
 Ale.
jdsilva
You can do this by configuring your content filtering rules in a Group Policy, and then applying that GP to a VLAN on an MX.
5 REPLIES 5
jdsilva
I've created a policy group and tested.
Is it correct the rule "*" I've applied which is intended to block all URLs except google.com?
When testing and connecting with an iphone to the SSID with vlan 532:
1. i can't see any clients affected by the group policy... it shows 0
2. The connected client is able reach any URL so basically it doesn't work.
If I go to clients I can see the client is connected to vlan 532:
Any idea what's wrong?
Sorry no need to reply...
I had something wrong configured on my end and now your solution is working!
RaphaelL
Hi Captain ,
If I'm not mistaken , the best way could be by applying a group policy to our VLAN  : https://documentation.meraki.com/zGeneral_Administration/Cross-Platform_Content/Creating_and_Applyin...
jdsilva
