URL Filter Wildcard
CotyMick
URL Filter Wildcard
Hey All!
Is it necessary to use the * before the domain that I wish to block or whitelist? I read while setting up group policies that all I need to do is use the domain like "google.com" without the * - Does this also apply to URL Filter on the Firewall?
Thanks!
Mick~
MacuserJim
In the L3 firewall rules you do not need to have the wild card, ie "google.com" would also allow (or deny depending on the scenario) "mail.google.com".
Another thing of note is using "*" in content filtering. When used alone it will act as a wild card for all URLs, but if used in a URL (ie "*.google.com") it will act as an asterisk character and NOT a wildcard.
4 REPLIES 4
MacuserJim
@MacuserJim Thanks!
CLEBERPENTEADO
@MacuserJim this rule about "*" is valid in trailing way too?
rdominguez
Hello @CLEBERPENTEADO,
As @MacuserJim has already indicated, even in a trailing capacity, the asterisk '*' will not be used as a wildcard but as part of the URL itself. If you have any questions about the rules pertaining to the use of the asterisk in this capacity, you can find them in our documentation which I am including below.
https://documentation.meraki.com/MX/Content_Filtering_and_Threat_Protection/Content_Filtering#Using_...
