Two hubs same organization routing table.
JamesMutie
Since hubs within the same organization peer to each other automatically, will this cause a problem with crushing spoke IP subnets in different networks?
Lets say spoke 1 peering with Hub 1  doesn't  need to communicate with spoke 2 peering with Hub 2.  Spoke 2 has similar IP Subnet like spoke 1. Am suspecting spoke 1 return traffic from hub 1 might be send to hub 2  hence causing a blackhole. Is this case. ? if for example spoke 2 decides to advertise a more specific route to HUB2.
I  am designing  for  several Hubs in one organization and each hub has over 30 networks. And there is possibility of similar IP Subnets in some networks
@JamesMutie yes, if you have two sites that both use, for example, 192.168.0.0/24, then change one to use a different range like 10.12.3.0/24.
If you move to the 10. range you can create almost as many sites as you like as there are 255 /16 networks with easy subdivisions to /24 (where you have large sites) or over 65,000 /24 networks.
You don't need to move all, just the ones that overlap.
There is an option to translate remote subnets to different ones in this case, but I'd always go for renumbering despite the initial pain.
JamesMutie
@cmr  Thanks,
Renumbering is changing the IP addresses to different ones right.
