Tunnels Slow to Re-Form After Firmware Update
TRBO_KCMO
Just bumped the firmware to 17.10.2 on MX84 hub. The spokes were completed already. After the update, it took a long time for spoke-to-hub tunnels to re-form, a few almost an hour. This is the first time we've tracked a firmware update on a hub, so I don't know if that is normal behavior. Seems like it. The spokes run the gamut of models, so we can't tie it to any specific model, even though we do have numerous Z3's on 18.107.
So my question is, how long should it take for tunnels to re-form after a firmware update to a hub?
7 Replies 7
Have you tried disabling all security policies? It's a known issue.
TRBO_KCMO
None defined, surprisingly enough
I'm used to it happening within minutes.  This is a long time.
Is the hub behind NAT without a manual NAT configuration?  That could impact recovery time.
TRBO_KCMO
That's where I was headed. I's in a DMZ  but with a manual NAT. Going to have to consult the FW team
Configure this option (except configure it for manual), and it will repair any issues very quickly:
TRBO_KCMO
Already set that way.
That would suggest that the configured UDP port is not being allowed in, or the configured public IP address is not correct.
