Tricky Situation
NolanHerring
Tricky Situation
Normal Spoke site, going to datacenter (HUB).
There is a URL that can only be accessed from inside the network, as it is hosted in AWS. However since I am using split-tunnel, it won't load (the IP is a public IP and it is whitelisting the company public IP).
Spoke site uses dynamic public IP so we can't whitelist.
Is there a way to send the traffic to this public IP (say 5.5.5.5) over the VPN tunnel, so that it goes through the tunnel and then out?
Full-Tunnel the site loads fine since traffic is going out the HUB.
Trying to avoid having to do full-tunnel mode
Nolan Herring | nolanwifi.com
TwitterLinkedIn
1 Reply 1
NolanHerring
And I'm an idiot. I kept looking at this from the SPOKE side instead of the HUB side.
All I had to do was add that 5.5.5.5/32 as a 'local network' on the data center MX (HUB) and it works now 😃
TwitterLinkedIn
