Throughput per device
MAB-
How could we ensure or plan for throughput per device/user?
and
is there any dynamic power or MIMO beam forming option to channel the bandwidth with dynamic power budget to particular area within omni-directional antenna range if more devices concentrate around that area?
BR,
M.
3 REPLIES 3
You've posted this under SD-WAN, but your question makes it sounds like you are talking about WiFi.  What type of device you do have?
If you are talking about MX devices have a look at this sizing guide.
https://meraki.cisco.com/lib/pdf/meraki_whitepaper_mx_sizing_guide.pdf
If you are talking about MR - and the information is a little vague to really answer - then AutoRF will take care of most of the issue for you.
https://meraki.cisco.com/lib/pdf/meraki_datasheet_auto_RF.pdf
You could also consider getting a professional site survey done by a local company to plan out AP quantity and placement.  Ekahau is a stand out product in this area that most professionals use.
https://www.ekahau.com/
I've never personally used it, but if you feel like splashing some cash, they also make a version for IT generalists now.  You'll probably get a better result getting an expert in surveys to do this for you though.
https://www.ekahau.com/products/ekahau-connect/survey
MAB-
Thanks the AutoRF does seem to address part of the question.
The second part; if there is any mechanism to ensure throughput per connected device or per host in the coverage area.
e.g. if 10 devices get roughly ~30 Mbps in a coverage area, how could one ensure service availability with some assurance of throughput, if more devices (say 50) concentrate in a coverage area dynamically at some point in time.
BR,
M
RF spectrum is shared, so there aren't any guarantees.
You can do per-user and per-ssid traffic shapping.
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/Simple_Traffic_Shaping_Strategy
You also have QoS options avaulable such as WMM, 802.11e and FastLane with managed Apple devices.
https://documentation.meraki.com/MR/WiFi_Basics_and_Best_Practices/Wireless_QoS_and_Fast_Lane
