We use it a lot for client either blaming AMP if they know what it is or saying they can't get to something (Software updates seems to be the most frequent). We use a group policy to turn AMP off and then apply it to their device. If it fixes the issue and is able to be reproduced then we add AMP whitelist to main settings and remove device from that policy.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_5b7cb728f6502","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_5b7cb728f6502_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_5b7cb728f6502_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_5b7cb728f6502_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_5b7cb6c65648f","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
