TLS client key exchange seems to fail across AutoVPN overlay
DennisS
We're currently testing SDWAN connectivity across our MPLS WAN.
  • At our branch location we have our MPLS circuit terminating into a MX67
  • MX67 connects to a downstream MS350 stack
  • At our data center, a MX84 pair sits behind our traditional Cisco routers running in concentrator mode
  • AutoVPN tunnel is established between MXs; connectivity is across our MPLS so no firewalls to traverse
From a PC at the branch location I run Citrix Workspace then select a published app. It sits there thinking for 2-3sec then does nothing. Tried this several times.
  • We took a packet capture from the MS350... TCP handshake between the PC & Citrix server is good, client starts TLSv1.2 connection, keeps retrying until the Citrix server resets the connection.
  • We rolled everything back to traditional MPLS and performed a packet capture... client starts the TLSv1.2 connections followed by the Client Key Exchange and so on until the published app. opens.
Anyone run into this before?
2 Replies 2
Sounds like an MTU squeeze to me (smaller packets making it through, large packets failing).
Try lowing the MTU on a test Windows machine.  From an Administrative command prompt:
netsh interface ipv4 show subinterface
Identify the name of the interface with all the traffic, and then:
netsh interface ipv4 set subinterface “<name>” mtu=1300
The above will cause a temporary change which is undone on reboot.  It will confirm this is or is not the issue.
DennisS
Thanks for the suggestion but it didn't make any difference on the PC. We also dropped the MTU on the MS350 stack, same results.
We hopped on a Web-ex with Meraki support and it appears the MX67 isn't forwarding the TLSv1.2 negotiation between the client & Citrix front end server (sits behind an F5). What's odd is, there are other TLSv1 & v1.2 convs from various devices that are working fine.  Meraki is reviewing logs and we're waiting for next steps to try.
