I just purchased two Cisco 8841 VoIP phones to experiment with (to determine if I want to replace my current system with VoIP phones). I am using a hosted service called Phone.com
My Meraki gear is: MX100, MS350 switches, Meraki WiFi-6 AP's
Even though I would eventually have a dozen or so Cisco 8841 VoIP phones, there would rarely be more than two people using the phone system at one time and those conversations are always less than 60-seconds.
I was reading some Meraki documentation, and it sounds like I need software running "TFTP Server" on a computer on my network. Most everything I've seen is for Windows PC's but I am all Mac here.
Typically, VoIP equipment will get a dynamic configuration from a TFTP server or other service on the network. This will commonly be levied by a DHCP server, where leases to VoIP endpoints will include voice-specific DHCP options. In the event that the phone fails to connect to the network/get a working configuration, consider the following recommended steps:
- If a separate voice VLAN is being used, ensure that phones are being put on the appropriate VLAN by means of an access port, voice VLAN configuration on the port, or even configured on the phone itself.
- If this is being done, ensure that a DHCP server is up-and-running on that VLAN, and configured with the appropriate scope and options.
- If phones have a working IP configuration on the network (or a static assignment is given for test purposes) and are told to get their VoIP configuration from some other server, ensure that the server is online and reachable from the voice VLAN.
https://documentation.meraki.com/zGeneral_Administration/Tools_and_Troubleshooting/VoIP_on_Cisco_Mer...
Anyone have experience with this?
