Syslog Hostname is inconsistant
PaulHenry
We have multiple MX-250 devices on the network and I am using rsyslog to collect my logs.
As of now, the hostname in the logs shows as "_gateway".  If I send logs from an Ubuntu host, I get the correct hostname in the log file,but not when the logs come from the MX-250.
Our MX-65 shows in the the syslogs with its IP address, as do all the access points.  Where is the "_gateway" name coming from for the MX-250?
Is there a place to set this in the configuration screens?
This is what the log entry looks like:
2019-01-25T15:38.16986678-5:00 _gateway 1548448.1704225745 ip_flow_end src=...
Thanks in advance for any ideas.
Accepted Solutions
PaulHenry
Re: Syslog Hostname is inconsistant
That is exactly what is happening!  It is the syslog server that is setting the hostname, not the MX-250
All I had to do was put an entry in /etc/hosts and restart rsyslog
Thank you.
-Paul
3 REPLIES 3
If you do an nslookup on the MX250 IP address it doesn't resolve to that name by chance does it?
BrechtSchamp
Any chance the syslog server puts it in there like that because it detects the source is it's own default gateway?
PaulHenry
Thank you.
-Paul
