Swap a MX64 with a MX75 - Client VPN issue
MauroF
I need to Swap a MX64 with a MX75 on the same network but im concerned about a possible Client VPN issue.
I mean..if the client connect to the hostname of MX..and i swap the firewall...is the hostname changing or it's going to keep that one?
I mean: MX64  has a hostname:  Test-mx01-edge-bkerjmtnkijc.dynamic-m.com
if i swap the mx the hostame is going to stay the same?
mauro
JamesT91
If you're using method 1 quick swap from this document then the hostname will stay the same: MX Cold Swap - Replacing an Existing MX with a Different MX - Cisco Meraki Documentation
2 Replies 2
JamesT91
MauroF
Yes ,indeed although it is not explicitly mentioned.Thanks anyway.It worked.
