Scenario is Z3 at home (10.10.0.0), plugged into home router (192.168.1.1/24). AutoVPN has default route enabled so all traffic is tunneled back to data center for proper inspection/internet egress.
Is there a way to add the 192.168.1.1/24 route to a tunnel exception so home personal printers may be used from the Meraki subnet (10.10.0.0)? Essentially, a static route with next hop being WAN uplink.
If you remove default route for the Z3 VPN to the DC hub it works perfect with home printer, but then *all* internet traffic egresses locally from home ISP, not via the DC.
As soon as you enable default route on the VPN all internet traffic goes to the DC and you lose home printing.
