Starting to mesh netwrk sites
Blackhorse
Just browsing
Hi All,
I am starting to replace ASA's with MX65's and MX100's. My question is this: The current ASA's are populated in the dashboard as Non-Meraki peers. The passwords are set for those S2S connections.  Currently, I have different passwords for each S2S connection. As I change out the ASA at the remote locations do I need to use the same passwords for all of the Site to Site connections?
2 REPLIES 2
It would make your life much simpler if you did.
However, could you just put a Meraki Hub at a site with an ASA that has a VPN to everything else?  If you did this all you would need to do is adjust the routing between the two as you cut the sites over.
Spooster
If you want to make it easier than I would recommend to use the same password for all. But if you want to make it more secure than I would recommend to use different for each.
