Splash Page
OBARRERA
Splash Page
How can I remove the User field and just ask me for the password on my splash page.
I want the user to be by default "admin" for example and that my users only enter a password.
Is it possible to do it with some option in my MX or should I do it from a custom splash page at code level?
1 Reply 1
Why not just use WPA2-PSK, and have a simple pre-shared key?
If you really wanted a splash page, you could use WPA2-PSK with a simple click-through splash page.
Otherwise you can probably modify the form with a custom theme:
https://documentation.meraki.com/MR/MR_Splash_Page/Custom_Splash_Page_Themes
Here is some info on the allowed HTML tags:
https://documentation.meraki.com/zGeneral_Administration/Cross-Platform_Content/Customizing_the_Spla...
