Splash Page Via Wired.
Aryinomoto
I need Authentication via Radius Server. At this time, I tested with Wirless. It works. But I want to test with the use of late, it appears that the splash page does not appear.
picture login use Radius server via AP
Does Meraki have a wired login function? Because I only see the login without wires.
I request more information or other methods
1 Reply 1
yes this works on LAN port to.
You need to have a MX/Z and enable it at the Securtiy & sdwan > access control.
make sure the port is set to access and has the correct vlan set, the same as you set for the access control.
