Source-based default route with Auto VPN
djgrothe
I have an MX84 that I would like to function as an Auto VPN hub and gateway for a segregated wireless network.
I'm looking to enable a default route that forwards all traffic originating from my Auto VPN to a next hop IP on a LAN subnet. This part seems to work fine with a VPN-enabled static route.
However, I would also like my wireless VLAN to ignore this route and use the WAN interface for outbound traffic.
I had initially planned to solve this by adding a source-based default route, but Meraki does not allow me to set the next-hop IP in the WAN subnet for some reason:
The other potential solution I can think of would be to add a source-based default route for just the Auto VPN traffic, but Meraki does not allow me to add IP ranges to the source that is not on a local subnet.
Has anyone else encountered this, or have any insight for another possible solution?
Thank you.
GreenMan
GreenMan
Why do you need the route for the inbound AutoVPN traffic to be a default one, to an a LAN-side destination?
I assume your MX is in routed mode and is also providing local firewall services for the site in question?
djgrothe
The MX is in routed mode, but we have a separate FTD firewall we would like to use for all internal-internet traffic. The LAN-side default route allows outbound traffic to be forwarded there instead.
This is in contrast to the segregated wireless traffic, which I would like to forward directly to the WAN ideally.
GreenMan
Just one thought;   You could maybe try linking your MX to your FTD via one WAN port and to it's own Internet link via the other WAN port - then use SD-WAN flow preferences to route Internet traffic from different sources via the appopriate WAN uplink.   Bear in mind that should an uplink fail then traffic would fail over to using the other link.
Note that you could still have your (non-wireless) local LAN traffic hit the FTD directly, by defining it as the Default Gateway for those VLANs (this would likely avoid asymmetric routing too) - but using an SVI on the MX as the gateway for your wireless users.
GreenMan
