Source based Routing via Dual WAN links Question on MX250
LeAnts
Hi All,
newby on meraki..
busy setting up a MX250 with basic config as a poc.
WAN1 connected to ISP1
WAN2 connected to ISP2
Port 3 connected to LAN
WAN ports are not live yet hence cannot test.
we want certain lan subnets to connect to internet via wan1 and others via wan2 (not using sd-wan and not using load balancing at this stage)
     - Will it work if I just define 'flow preferences' for certain source networks via wan1 / wan2 ie in the  'SD WAN and traffic Shaping' section?
         192.168.10.0.24 > ANY > WAN1
         192.168.20.0.24 > ANY > WAN1
          172.16.10.0/24 > ANY > WAN2
          172.16.20.0/24 > ANY > WAN2
 It seems not to be possible to define a source based route for wan interfaces under the 'Security SD-WAN\addressing    and vlans' section, can only do this for non-WAN interfaces it looks like.
is this the correct process to follow?
thanks in adv
2 Replies 2
LeAnts
GreenMan
Meraki Alumni (Retired)
Correct - as per this document, source based default routing (chosen per-VLAN) only allows two types of next-hop:
An IP directly attached via a local VLAN
A remote MX, to which the MX in question is linked via an AutoVPN tunnel.
To specify a different WAN link for each VLAN, you need to use the subnet in use on each VLAN, in the way you describe, within the SD-WAN config.
https://documentation.meraki.com/MX/Networks_and_Routing/Source_Based_Default_Routing
