Site-to-site outbound firewall best practices?
dalmiroy2k
Hi guys, I currently running a Hub-and-spoke topology and I only need remote endpoints to reach both a local DNS and an HTTPS internal web page in the HQ subnet.
So far I have enabled those subnets and ports and a implicit deny all at the bottom (on top of the implicit allow all).
My objective is reduce malware propagation and threats originated internally through the VPN (Ports scans, DDoS). Both Endpoints and HQ have Advanced licence with IDS set @  Prevention / Security
I was wondering what are you Site-to-site outbound firewall best practices? Any other tip to control and secure VPN usage?
Thanks!
BrechtSchamp
Seems to me that by doing this you'll be blocking all port scans through VPN. Simply because only requests to the ports you defined will be allowed. A DDoS to the HTTPS or DNS servers would still be possible, but then someone would need to launch a coordinated attack with multiple infected clients in your remote networks. To mitigate that I'd recommend to deploy an endpoint security solution.
I noticed that you're allowing traffic to whole /24 subnets though. Is that necessary? Why not just the /32 of the specific  server(s)?
2 REPLIES 2
BrechtSchamp
Great point BrechtSchamp. /24 subnets were allowed during initial setup but I should setup the servers addresses only.
