Site to site VPN to AWS without using vMX
acnteam
We have two sites we implemented Meraki SDWAN. Each site has dual links redundancy from two different ISPs, and each link is connected to one of the two MX67 for hardware redundancy. The goal we are trying to achieve is to connect each site to AWS and utilise the two links for redundancy. AWS creates two tunnels with two separate public facing IPs, however, Meraki can only accept one IP at the time and routing to the second tunnel is not possible. Without purchasing vMX, I was wondering if anyone has found a reasonable work around other than changing the AWS public IP of the tunnel. Does VPN tagging would work for AWS? If so please provide more information
1 Reply 1
With a vMX within AWS this is not a concern as you can use Meraki's auto VPN.
https://meraki.cisco.com/product-collateral/five-ways-to-use-vmx-on-aws/?file#:~:text=The%20vMX%20of....
https://documentation.meraki.com/MX/MX_Installation_Guides/vMX_Setup_Guide_for_Amazon_Web_Services_(...
