Site to site VPN keeps dropping intermittently
HarleyPhreak
Keep seeing these messages in my event logs. We have times where the tunnel(s) will drop randomly and come back up. When this happens it breaks database connections and occasionally corrupts data. Any idea what is causing this? Opened a support case and would like to point them in the right direction.
Oct 24 00:24:13 Meraki VPNVPN tunnel connectivity changevpn_type: site-to-site, peer_contact: 216.195.43.41:57236, connectivity: true
Oct 24 00:24:11 Meraki VPNVPN tunnel connectivity changevpn_type: site-to-site, peer_contact: 216.195.43.41:57236, connectivity: true
Oct 24 00:23:56 Meraki VPNVPN tunnel connectivity changevpn_type: site-to-site, peer_contact: 216.195.43.41:57236, connectivity: false
Oct 24 00:23:55 Meraki VPNVPN tunnel connectivity changevpn_type: site-to-site, peer_contact: 216.195.43.41:57236, connectivity: false
Oct 24 00:20:15 Meraki VPNVPN tunnel connectivity changevpn_type: site-to-site, peer_contact: 216.195.43.41:57236, connectivity: true
Oct 24 00:20:13 Meraki VPNVPN tunnel connectivity changevpn_type: site-to-site, peer_contact: 216.195.43.41:57236, connectivity: true
Oct 24 00:19:56 Meraki VPNVPN tunnel connectivity changevpn_type: site-to-site, peer_contact: 216.195.43.41:57236, connectivity: false
Oct 24 00:19:55 Meraki VPNVPN tunnel connectivity changevpn_type: site-to-site, peer_contact: 216.195.43.41:57236, connectivity: false
Oct 24 00:19:33 Meraki VPNVPN tunnel connectivity changevpn_type: site-to-site, peer_contact: 216.195.43.41:57236, connectivity: true
Oct 24 00:19:29 Meraki VPNVPN tunnel connectivity changevpn_type: site-to-site, peer_contact: 216.195.43.41:57236, connectivity: true
Oct 24 00:19:03 Meraki VPNVPN tunnel connectivity changevpn_type: site-to-site, peer_contact: 216.195.43.41:57236, connectivity: false
Oct 24 00:19:01 Meraki VPNVPN tunnel connectivity changevpn_type: site-to-site, peer_contact: 216.195.43.41:57236, connectivity: false
Oct 23 21:45:32 Meraki VPNVPN tunnel connectivity changevpn_type: site-to-site, peer_contact: 216.195.43.41:57236, connectivity: true
Oct 23 21:45:31 Meraki VPNVPN tunnel connectivity changevpn_type: site-to-site, peer_contact: 216.195.43.41:57236, connectivity: true
Oct 23 21:45:21 Meraki VPNVPN tunnel connectivity changevpn_type: site-to-site, peer_contact: 216.195.43.41:57236, connectivity: false
6 Replies 6
pmhaske
Hi @HarleyPhreak,
The first thing that comes into mind with VPN tunnel connectivity flaps is intermittent packet loss or congestion in the internet pathway between the peers. Check if there is an indication of this in the default ping to 8.8.8.8 under the uplink tab in appliance status of the peers. Also consider adding a connection monitoring ping to public IP addresses of peers to see if there is a correlation between loss and latency at the timestamp when tunnel changes occur.
Ih this by chance an IKEv2 VPN and you have more than one subnet in the source or destination encryption domain?
pmhaske
This looks like AutoVPN issue based on the 'Meraki VPN' field, IKEv2 based negotiation would be for IPsec or Non-Meraki VPN tunnel.
Any chance you can get a log from the other end to see what it thinks is happening?
Is either this MX or the MX at the other end behind something doing NAT?
HarleyPhreak
Meraki support says they see flapping on the circuit at the far end, so I have opened a ticket with the ISP to have them investigate. Thanks for the input...will update once the ISP does their thing. Hopefully, them fixing that will resolve the issue.
