Site to Site with Azure not connecting
Ajasinski
I have been spinning my wheels for a while on this, hope someone here can point me in the right direction.  I cannot get Meraki to connect via site to site VPN with Azure.  Event log shows "msg: phase1 negotiation failed due to time up."  I looked at this article- https://documentation.meraki.com/MX/Site-to-site_VPN/Troubleshooting_Non-Meraki_Site-to-site_VPN_Pee... but it got me nowhere.
I followed this guide- https://www.virtualizationhowto.com/2017/08/configure-meraki-to-azure-site-to-site-vpn/  and from what I can tell I have everything setup correctly.
We are using the MX450, if that makes a difference.
MacuserJim
Have you tried pinging from the MX to Azure to make sure you can hit it? Have you also done any pcaps to see what traffic is being sent/received?
Also have you considered using the Meraki vMX in Azure?
Ajasinski
Ping is okay, haven't done a pcap yet- was hopeful it was just something simple I was missing.  I was not aware that was a Meraki vMX in Azure- definite going to explore that option- thanks!
MacuserJim
You're welcome! I use a vMX in AWS and it is super helpful. If/when you do any pcaps let us know what you find.
There will be a mis-match in your phase 1 settings.  The first thing I would check is the PSK.  Have a mis-configured PSK will cause this.
Next check the crypto settings, and the lifetime being used, and make sure they all match.
