Site to Site or MPLS
AlexanderDrago
Hello!
I have a question.
I have read about MPLS in Meraki and dont cleary understand.
Site to Site work without MPLS good, but what improvements give for us MPLS ?
As i see in Meraki configuring MPLS like routing and Site to Site create routes too
Thank you
3 REPLIES 3
Meraki SD-WAN over MPLS can be done with guaranteed latency etc. and only needs enterprise license.  If you use internet circuits then you will have a more variable latency and it is advisable to have the protection that the advanced license gives you.
In the UK where you want a dedicated fibre circuit, they cost the same so the MPLS WAN option works out cheaper overall, with our provider the MPLS is L2 so the MXs actually see each other on the WAN ports, no hops in between.
As @cmr says, this is really dependent on your country.  In my country, no one uses MPLS for new networks anymore.  SD-WAN has killed it.
Depending on the service providers in your country, MPLS may offer:
  • Different SLAs
  • Different guarantees of performance
  • Different types of access technology may vary at an address depending on the product being selected
KarstenI
One more benefit of using MPLS compared to internet transport:
If you need Multicast between your sites, it will be much more efficient with MPLS. But not all ISPs support Multicast with their offerings.
