Site to Site VPN tunnel get dropped for few second or minute and back again
Preyash18
Just browsing
WE have site to site VPN between our 2 offices . Tunnel is get drop time to time and re-established in few second some time in few minutes. Can not find on event log of the MX devices. Any one ca help me to resolve this issue?
Many thanks,
Preyash
Smokey1969
Just browsing
We have been having the same issue for the past month. Currently no resolution.
Regards,
Smokey
GIdenJoe
Make a case to Meraki support.
Check if your VPN registry connection is stable. (check on VPN status page)
Try to do a packet loss check between both peers.  Perhaps try to use the WAN IP of one site on another as uplink test.
PhilThacker
Did you ever discover the core issue on this?
Smokey1969
Just browsing
Hi PhilThacker
Yes! An update had happened a month before and I had been busy with other problems and had not read what changes had been made.
Meraki now supported IKEv2 Once I set that version on my tunnels then everything became rock solid. For some reason support could not
tell me that it was the issue. I had to read through a lot of documentation before I realized what I had missed. The positive note is I read all the update
docs now before they update my device.
Regards,
