Site-To-Site VPN extremely slow
ibarrasaualfred
Hi all,
I hope this finds you well.
We recently add to our infrastructure a SD-WAN Velocloud solution,
 We have 2 locations, both with 1Gbps for Download and Upload.
And the connection to internet is really very cool, but the connection Site-To-Site is extremely slow.
The file transfer between servers, one in every location is about on 355 Kb/s.
What could be causing this?
Thanks in advance.
Regards.
14 Replies 14
Which MX model do you have? Have you opened a support case yet?
ibarrasaualfred
1: MX105
2: MX250
I created a case to Meraki also for my velocloud provider, and both sides say everything is fine in their side.
We connected both places with a LAN connection, and everything was slow between them.
Is there any shaping rule that I can create for prioritize the file transfers between the servers?
Thanks in advance!
Take a look at the documentation.
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/SD-WAN_and_Traffic_Shaping#SD-WAN_p...
ibarrasaualfred
I could not find nothing relevant for solve my problem.
Thanks for your time!
Is your topology at each site as below?
LAN - Meraki MX - VeloCloud - Internet
If so, can you connect a test client in place of the Meraki MX and see if that works okay?
Also do you have a large SD-WAN, I ask as if you just have two sites, why not use the SD-WAN features of the Meraki MX?
ibarrasaualfred
Hi, yes my topology is like that one!
We don´t use the Meraki SD-WAN for another reason, but I cannot figure out yet, why if a copy a file from my computer to the server is very fine, but from the server to my computer is very slow...
I don't know what is your operational system but maybe it will help you.
https://answers.microsoft.com/en-us/windows/forum/all/how-to-change-mtu-settings-in-windows-10/5c36c...
Obrez
Make sure your MX appliances are on the same version of firmware.  Also open a ticket with support, you may have some sort of MTU mismatch.  They will have you run some iPerf and do some other testing.
If I understand correctly, you are using Velocloud for SD-WAN and Meraki MX to act only as a security appliance.
As Velocloud is providing the SDWAN between the sites - that is where you'll need to look for the issue.
My guess - it is an MTU squeeze in Velocloud.  You can test this on two machines by temporarily lowering their MTU to something like 1300 and see if the issue goes away.
You need to find the name of the network adaptor being used with this command:
netsh interface ipv4 show subinterface
Then run this command to change the MTU (change "Local Area Connection" to the adaptor name above):
netsh interface ipv4 set subinterface “Ethernet” mtu=1300 store=persistent
ibarrasaualfred
Hi !
I tried changing the MTU and both sides.
It is still slow.
The weird thing is when I copy a file from my computer to the server, it has a good speed, the problem is when I copy a file from the server to my computer (or any computer in my domain)
AlexP
The best way to troubleshoot this is to start a packet capture, and then start your file transfer; there's a few details Support can reference in such a capture to help determine where it's bottlenecking better.
ibarrasaualfred
Hi, thanks for your reply.
Actually I did a package capture, but we cannot determine was was happening
It only shows lost packages
AlexP
Packet loss could easily be the cause of reduced performance though
tam29
Has anyone found a solution for this?
I have a similar problem, using netbird VPN. It kept wondering me why the copying speed seems to freeze on 355 KB/s; googling that brings up some post where people had wrong subnet setting. no idea where in my case, because there are some (private) hops used to reach my VPN destination.
Someone else talks about an IPsec firmware bug: https://community.fortinet.com/t5/Support-Forum/Slow-VPN-speed/m-p/1259/highlight/true
