I have branch office using a 10.0.0.0/24 LAN subnet with a Meraki MX appliance. The LAN connects back to the home office on VPN and everything works great. The problem is that they share physical space with a cooperative 2nd office that I'm not the admin of, and the two offices share printers and a local NAS file server. The 2nd network is a SonicWall on a flat network LAN of 192.168.0.0/24 with no VLANs defined.
The previous Cisco 1841 router simply did this to make it work:
interface FastEthernet0/0
description 2ND LAN Interface
ip address 192.168.0.135 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
duplex auto
speed auto
I've tried defining the 2nd network as VLAN 2 with the correct LAN & same IP, verified the physical port connection, made sure the port is trunking, but no joy. I've got to be missing an obvious solution here because it's not supposed to be this hard. (or so I'm told)
