Setting up TFTP on MX68 to upgrade switches in LAN
Tarmahmood1
I am struggling in setting up TFTP setup in Meraki.
HLD
multiple switches---->Cisco switch(2960) ---> Meraki (MX68) ---> vMX ---> Azure(VM with TFTP server)
Meraki configuration:
FW rules : allowed all traffic
configure --> DHCP --> VLAN1(MGMT) -->DHCP options --> Custom --> code 66 --> IP for TFTP server(azure vm private IP)
vMX
no change
FW: all traffic allowed
Azure(VM)
installed TFTP64 software
also tried Solarwind TFTP
Output: Azure VM is pinagble from switch, but when trying to transfer file says no connection for tftp. any idea
Tarmahmood1
Hi, It worked while adding rule in windows firewall 1. TFTP port and 2. TFTP application. I didnt added TFTP application rule. That's why it was not transferring.
2 Replies 2
Host firewall on the TFTP server (try turning off Windows firewall)?  Azure network security group allowing TFTP?
Tarmahmood1
