Sending an entire network over a WAN
Bartounet
Hello.
I have an MX with two WANs.
I'd like an entire local network to always go through WAN1.
I don't understand the destination network to specify.
It doesn't accept 0.0.0.0/0
we cannot set ANY !!
GreenMan
Meraki Alumni (Retired)
10.10.84.126/25 isn't a subnet, it's a host
I think you'd want 10.10.84.0/25, to cover that subnet   (.126 is the last usable host in that)
The default destination would, I think, be Any - as per the other columns -  (but in dotted decimal would be 0.0.0.0/0
5 Replies 5
michalc
Hi There,
Why ANY can't be used? Do you get an error when using ANY?
Just set the Primary Uplink for WAN1, disable load balancing and you have the entire network using WAN1. No need for Flow Preferences to be set.
If you really want to keep WAN2 and use the flow preferences you would replace the destination of 0.0.0.0/1 with ANY just like on the screenshot.
MX Load Balancing and Flow Preferences
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
GreenMan
Bartounet
Thanks for answer.
Yes it is an error subnet is 10.10.84.0/25
0.0.0.0/0 is not authorized
any is not authorized
Bartounet
I am sorry Any woks ( do not forget A Capital Letter ..)
Bartounet
