Sanity Check Performance SD-WAN
squidgy
Hello All
We've just moved our DR site to another branch, connected on SD-WAN to our head office both on upgraded 200/200 Mbps links.
We're investigating somewhat lower performance doing data backups and wanted to check what we should be expecting.
Checking the mx sizing guide for the MX64
Max site-to-site
VPN throughput 100 Mbps
Can someone confirm for me this is the SD-WAN limit per site? Assuming it is I need a higher tier mx?
Our backups are running at around 5MBs fyi - it could be a veeam issue of course.
8 REPLIES 8
CptnCrnch
100 Mbps should be perfectly reachable depending on the type of traffic. 5 Mbps instead of 100 seems very odd though.
Have you checked for duplex mismatches within that environment?
Hi Thanks for responding.
it was 5MBs not 5Mbps sorry I changed the nomenclature.
i'll take a look but they're all set to auto-negotiate.
is 100 the max pipe we can expect on SD-WAN on MX64?
Yes 100Mb/12MB is the rated tunnel throughput .
squidgy
right ok...
bad practice I know, but checking everything (we have no traffic shaping) we're getting around half of the speed on the CBT backup in veeam.
At least now I know the target we should be after.
Ok so the branch mx is connected to a MS switch. I can see the duplex is auto 1Gbs. looks fine.
The source mx connected to a catalyst, that's also 1Gbps full duplex.
I don't think it's a duplexing issue but can see why you suggested it.
is there anything else I can check?
Inderdeep
@squidgy : Yes it supports 100 Mbps of course, For back on Veeam, can you tell me what bottle neck tooltip tell you on Veeam ?
Regards
Inderdeep Singh
www.thenetworkdna.com ( Awarded by Cisco IT Blogs award 2020)
Inderdeep.
Bottleneck is network.
We run a veeam proxy at both sites as per best practice.
You can do some iperf test between 2 locations to see what throughput you can get/expect.
https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Troubleshooting_Cl...
squidgy
@ww  that’s a great suggestion I’ll do that tomorrow or Monday. Thanks.
