SDWAN polices not working on wireless WHY
AnkitSharma1
We’ve noticed that when we apply SD WAN policies on our Meraki MX, they work correctly on wired connections but have no effect on our Verizon wireless (cellular) uplink. Latency is not getting reduce on wireless.
Can anyone explain why SD WAN policies don’t apply or don’t have any impact on the Verizon wireless router
We have MX connected to Verizon Internet Gateway and I am trying to apply VPN traffic
5 Replies 5
Verizon and other mobile carriers often use carrier-grade NAT, which hides the real public IP behind a shared IP, and this can interfere with VPN performance, path selection, and latency-based routing as the MX may not get accurate uplink telemetry.
But it would be interesting to contact support to confirm this.
RaphaelL
What do you mean : they work correctly on wired connections but have no effect on our Verizon wireless (cellular)
You mean the cellular uplink on the MX ?
AnkitSharma1
I mean we have some other with leased line. VPN polices works fine, we are able to reduce the site to site latency however it does not work on wireless connections
RaphaelL
Exactly what do you mean by "wireless connections" ?
WAN 1 is WAN 1 and WAN 2 is WAN 2 , the MX doesn't "care" what ever you use on the back. It can be a DSL link or a cradlepoint with a LTE connection , it doesn't matter ( or shouldn't matter )
AnkitSharma1
Verizon Wireless Business Gateway
