I am currently testing the SD-WAN capabilities of Meraki and its abilities to select the best link based on WAN links’ performance.
I have 2x low cost WAN links on a remote site 50/20Mbit and a high-performance Fiber link 100/100Mbit on the Hub site. Both sites are configured to use NAT, while the HUB is configured as a Hub and remote site as Spoke.
On the remote site, I have defined WAN1 as the primary uplink and have enabled Load balancing.
5x VPN traffic Uplink selection policies have been defined, each one configured to load balance on uplinks that are suitable for their respective performance class. Uplink selection policies have both application based and custom definitions. For example for the Voice, I have defined to use the uplink that’s best for VoIP traffic, using the traffic filters: Skype, SIP (Voice), (UDP from Any to Any:5060-5061)
5x performance classes have been defined, including the default voice class.
Additionally, 6x traffic shaping rules have been defined, reflecting the above Uplink selection policies (same application assignments), where Voice (EF) and AF41 classes are assigned as high Priority (2/7 of the total bandwidth each), AF31 and AF21 are assigned to normal (1/7 each) and the rest of the traffic as Low. No bandwidth limits have been applied.
Based on my understanding of the documentation, I would expect that the outgoing traffic through the VPN should be marked as defined on the traffic shaping rules and in the occasion of link congestion the bandwidth allocation should be as defined in the priority classes (for example on Voice’s case it would be 20Mbit x 2/7 = 5.7Mbit).
First question: Given that I have 2x 50/20Mbit WAN links, would that bandwidth be 2 x 5.7Mbit? What is the expected behaviour?
Second question: On the Security appliance/ VPN Status, shouldn’t I see the applied policy per connection, as defined above?
