Dual WAN links. Cloud based pbx with a flat network. Only voice is on network. Can you use uplink preferences for SD-WAN policies under VPN traffic or does that only apply it across the auto vpn tunnel?
Solved! Go to solution.
That only applies to AutoVPN.
Thanks. I thought that might be the case but wanted to make sure.
