SASE in other SDWAN product
Fanny
Just to understand:
1. Is Cisco SASE can be used in those environment that using other brand SD WAN?
2. Is Cisco SASE can also deployed independently in multicloud environment without any SD WAN as connection especially for remote workers?
KH
Hey @Fanny
Meraki's SASE solution, Secure Connect, can only be used within the Dashboard and is only compatible with Meraki.
Cisco has another product called Secure Access which is more suitable for your use case:
https://www.cisco.com/site/us/en/products/security/secure-access/index.html
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
2 Replies 2
KH
Hey @Fanny
Fanny
Thank you for your explanation. Really appreciated.
