Route table not displaying?
RWelch
Anyone else having problems getting the route table to display?
Brash
Do the routes show if you revert back to the old version of the page (top right of the screen)?
I have some networks (but not all interestingly) in which I don't see any routes using the new version of the page but can see them fine when reverting to the old version of the page.
9 Replies 9
Normal here, have you tried it in another web browser?
CptnCrnch
Any issues on several Browsers and Platforms.
RaphaelL
What is the current size of your route table ?
RWelch
I've tried 3 different browsers.  9 networks and none show route tables.Screenshot 2024-01-09 at 08.49.16.png
CptnCrnch
So you're searching for Security & SD-WAN > Monitor > Route tabl
https://documentation.meraki.com/MX/Networks_and_Routing/Route_Table
RWelch
Yes - it only shows default wan routes.  My pic above was in response to how big routing table would (should) be for the largest org out of the 9 networks.
RaphaelL
Local prefixes are not displayed in the routing table. I don't know if that is expected but I have the same behavior.
Brash
RWelch
I just tried your suggestion and YES - they do now show.  Interesting!  Thank you.
