Route-based tunnel supported?
JuanjoG
Hello Experts,
Appreciate if somebody can tell me if Meraki support route-based tunnel.
Best regards
pdeleuw
Auto VPN is route-based. The reachable networks are announced to the peers via the registry (no IKE in Auto VPN).
For non-Meraki peers, route-based tunnels are not supported, only policy-based tunnels (crypto map).
12 Replies 12
I think that you are talking about PbR: https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...)
Take a look on the SD-WAN policies.
JuanjoG
Try again. https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...)
JuanjoG
Thank you very much for information.
For an IKEv2 VPN to a non Meraki device - it is not supported.
JuanjoG
Fine, that's the reply I was waiting.
Tishman
Hi Philip,
Is there any update about any enhancement for route based vpn with non-meraki  for future update
There have been no changes in this area.
Tishman
thanks
pdeleuw
JuanjoG
Thank you very much to explain it.
You give me the answer key...
YES, it's supported with auto VPN.
but is NOT supported for non-Meraki peers.
