We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Hello Experts,
Appreciate if somebody can tell me if Meraki support route-based tunnel.
Best regards
Solved! Go to solution.
Auto VPN is route-based. The reachable networks are announced to the peers via the registry (no IKE in Auto VPN).
For non-Meraki peers, route-based tunnels are not supported, only policy-based tunnels (crypto map).
I think that you are talking about PbR: https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...)
Take a look on the SD-WAN policies.
Try again. https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...)
Thank you very much for information.
For an IKEv2 VPN to a non Meraki device - it is not supported.
Fine, that's the reply I was waiting.
Hi Philip,
Is there any update about any enhancement for route based vpn with non-meraki for future update
There have been no changes in this area.
thanks
Thank you very much to explain it.
You give me the answer key...
YES, it's supported with auto VPN.
but is NOT supported for non-Meraki peers.
