Reverse proxy behind MX appliance
idknow
Hello all,
Have anyone ever used a reverse proxy behind a Meraki MX (mx in routed mode).
I have to make an inside server available from the internet by using a reverse proxy and not sure how to make it work, the architecture would look like this i guess:
Do you know where i can find some information on the different steps of configuring the mx to make it work please regarding port forwarding, nat, rules etc...?
Regards,
Ludovic
4 REPLIES 4
Inderdeep
@idknow : Check this below link
https://documentation.meraki.com/MX/NAT_and_Port_Forwarding/Port_Forwarding_and_NAT_Rules_on_the_MX
Regards/Inder
www.thenetworkdna.com
Thank you for the documentation, it really helps 🙏
If it is just a proxy server (no security software running on it) - then don't bother using it.  Instead of setting up the NAT/PAT on the MX to the reverse proxy, point it directly at the server you want to give access to.
Yes, but unfortunately the customer is asking for a reverse proxy in a DMZ like in the picture i've shown above, and then the traffic would be forwarded to the backend web server
He already asked for a dns public registry of an URL  xxx.xxxx.com
so i guess the idea is to map this url to the public IP address of the provider router and then port-forwarding the traffic on the MX towards the reverse proxy, am i missing something because that seems simple , what do you think ?
Regards,
Ludovic
