We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
In Meraki firewall can we restart IPsec tunnel service?
Solved! Go to solution.
No, but...
For non-Meraki VPN peers you could leverage the tag feature to remove the VPN from that network, then add it back in.
For AutoVPN you could turn off the site-to-site VPN setting and then turn it back on.
Or, reboot the MX.
