Request for step-by-step configuration + screenshots for NO_PROPOSAL_CHOSEN (MX85 → MX64)
palakshah
Just browsing
NO_PROPOSAL_CHOSEN error — I’m not fully confident interpreting it and would like step-by-step guidance to get a secure IPSec tunnel working between our devices.
My topology: Hub / starting point = MX85 → Spoke / ending point = MX64.
Main Requirement :- IPsec Tunnel  Between  mx85  to  mx64    --very secure tunnel  with full  control   to send and receive  data between  two mx devices
Could you please provide a clear, easy-to-follow configuration guide (with screenshots) that includes:
  1. Exact UI steps and screenshots for the pages/fields to set on both MX85 and MX64 (menu path + fields to fill).
  2. Recommended Phase 1 (IKE) parameters (exact values you want me to enter):
    • IKE version (v1 / v2)
    • Encryption algorithm(s)
    • Hash / integrity algorithm(s)
    • DH group
    • Lifetime (seconds)
    • Mode (Main / Aggressive) and NAT traversal settings
  3. Recommended Phase 2 (IPSec) parameters (exact values):
    • Encryption / integrity algorithms
    • PFS (on/off and DH group)
  4. Exact format/requirements for the pre-shared key (length/characters) and any best practices for generating it.
  5. Any Meraki-specific requirements (for MX→MX vs. Meraki→non-Meraki peers) that I should be aware of.
  6. NAT, firewall, or port-forwarding considerations that commonly cause NO_PROPOSAL_CHOSEN.
  7. A short verification checklist or UI checks I can run after configuring each side to confirm proposals match.
  8. Examples or annotated screenshots of the VPN log entries you want me to capture if the problem continues — please show the exact log lines to capture.
  9. If possible, a “copy-paste” example of Phase 1/Phase 2 proposals that will work for MX85↔MX64 to avoid negotiation mismatch.
RWelch
Are both MX in the same organization (S2S VPN)?  Or are you trying to use NMVPN?
Site-to-Site VPN Settings
Meraki Auto VPN - Configuration and Troubleshooting
RWelch
palakshah
Just browsing
Meraki Device --Mx 85 to    Mx 64
Non Meraki  IpSec  Tunnel
palakshah
Just browsing
both  are  different   different  --organization    --NMVPN  IS  MY  MAIN   POINT
palakshah
Just browsing
 please share best solution  &  documentation for "Configuring Site-to-site VPN between MX Appliances in Different Organizations".
