Redundant passthrough MX
MishMash
Hi everyone,
I've got a question from a customer of ours that I don't have a direct answer to. The customer (using only Meraki hardware) has got a Layer 3 stack with several vlan interfaces configured (some for the server vlans, some for the client vlans). The customer wants to bring up the security by placing two Meraki MX units between the core stack and the L2 switch stack where all the server are connected to. Currently, these two stacks are connected with a redundant 10G (LACP) connection.
Normally this wouldn't be a problem, just put an MX in passthrough mode, put it in between the 10G connection and you're done. But the customer also wants redundancy..
I think connecting this as a Passthrough HA setup would result in a L2 loop, so RSTP would block one of the ports. But configuring with translation would limit the throughput to 6GB (with the MX450's).
What would be the best configuration in this case?
Some hardware platforms support port bypass mode.
https://documentation.meraki.com/MX/Other_Topics/Port_Bypass_on_the_MX_Series
MishMash
That's interesting, but would that work for SFP ports?
*Edit*
I gave it another thought. But that would mean that all sorts of security go offline when one appliance fails. I don't think that this solution will be accepted by the customer...
MishMash
*bumb*
Does anyone else have an idea?
